Specifying your logger settings
The Logger Settings page allows you specify a log level and capture that information. Once you have specified a log level, you can export the log to a .zip file that contains multiple .txt log files. The following log levels are available for selection:
Error: This log level is used to find any error which is fatal to the operation, but not the service or application (can't open a required file, missing data, etc.). These errors force user (administrator, or direct user) intervention. These are usually reserved for incorrect connection strings, missing services, etc.
Warn: This log level is used to detect application oddities. Such as switching from a primary to backup server, retrying an operation, missing secondary data, etc. This level is selected by default.
Info: This log level is the default level. This level provides useful log information for general SmartHub processes (service start/stop, configuration assumptions, etc).
Debug: This log level provides Information that is diagnostically helpful to people more than just developers , such as IT support, sysadmins, etc.)
Trace: This log level is used to trace the code and find one part of a failing operation, specifically.
Access the log files
The log files are located in the logging folder of the SmartHub directory. For example SmartHub/<SmartHub-7.x.x.x>/Logging.
Export the log files
You can export the log files according to the selected log level from the Logger Settings page:
In the SmartHub admin portal, click Logger Settings under Administration in the left pane.
In the Log Level field, select the specified log level from the drop-down list.
Click Export Logs.
A .zip file containing the logs is downloaded to your browser. You can extract this file to view the logs. The format of the exported log file is yyyy_mm_dd-hh_mm_ss-SmartHubLogs.zip.
Delete the log file
Click Delete Logs. This clears the logging folder in the SmartHub directory.
Specify the name and location of your logger file
Open the web.config file in a text editor.
To specify the name of your logger file, add the following line:
<add key="log4net.Config" value="Logger.config" />. Replace the value with your desired file name. -
To Specify the location of your logger file, add the following line:
<add key="LoggingFolder" value="~/Logging" />. Replace the value with your desired file location. -
Save your changes.
