How to Enable Editing in the Content Intelligence Panel
The AppBus integration enables you to configure the Content Intelligence panel to support editing the information.
About
To enable editing, create a custom Content intelligence display template and customize it to support editing. By default, the Content Intelligence template is stored at \modules\ContentIntelligence\templates\modalTemplate.html.
Note: The Content Intelligence template is overwritten when SmartHub is upgraded.
See here to learn how to create your own Content Intelligence template.
How to Modify the Content Intelligence Template
In your own Content Intelligence template you have access to the functionality described in the sub-topics below. You can use the code blocks to enable editing in each section.
How to Enable Editing in Spans
Make a span editable or not by adding the attribute
data-edit="true"to the element:
Editable field
<div class="sh-form-group">
<label class="sh-form-control-label">Collection</label>
<span class="sh-form-control" data-edit="true"><%= result.CollectionName %></span>
</div>
Requirements
Note that an editable span that is not mapped to any parameter (see point 2 below) is ignored.
How to Map Spans to Parameters
Map a span to a parameter that needs to be passed to the AppBus flow by adding the attribute
data-integration-mapTo="<name of parameter>":Read-only mapped field<div class="sh-form-group">
<span class="sh-form-control" data-integration-mapTo="parameter1"><%= result.CollectionName %></span>
</div>
Editable mapped field<div class="sh-form-group">
<span class="sh-form-control" data-edit="true" data-integration-mapTo="parameter1"><%= result.CollectionName %></span>
</div>Requirements
Please note that while the spans that are mapped as parameters can be editable, it is not a hard requirement.
If a field is mapped, but not editable, the current value (inner HTML) is passed over as a parameter as-is.
How to Create a Trigger Button to Run AppBus Flow
Create a trigger button that reads all parameters and runs the AppBus flow by specifying
data-integration-url="<relative URL to the flow>":Trigger button<div class="sh-modal-footer">
<button class="sh-button" data-integration-url="api/contoso/documents/update">Save changes</button>
</div>
