Prerequisites: SmartHub with SharePoint Online
Installation Prerequisite Checklist
Prerequisites  Requirement Description Completed
SmartHub Server: OS
Operating System Microsoft Windows Server
  • 2016
  • 2019
  • 2022
SmartHub Server: Windows Roles/Features Windows Roles and Features Must have Web Server(IIS) role enabled with the following Roles selected:
  • Common HTTP Features
  • Health and Diagnostics
  • Performance
  • Security
  • Application Development
    • .NET 3.5
    • .NET 4.6
      • ISAPI Extensions
      • ISAPI Filters
      • WCF Services
        • HTTP Activation
  • .NET Framework 4.6 Features
    • WCF Services
      • HTTP Activation
SmartHub Server: .NET Framework .NET Framework
  • .NET Framework v4.7.2
    • Required for Windows Server versions:
      • 2012, 2016, 2019
  • .NET Framework v4.8
    • Required for Windows Server version:
      • 2022
      • Included with Windows (used automatically, by default)
Accounts: Service Service Account (domain\user)
  • Local or network service account used to run the SmartHub Application pool in IIS
    • Must be in the format domain\user
    • Requires read/write access to the directory SmartHub is installed in.
Account credentials: (domain\user)
Accounts: Installation Installation Account (domain\user)
  • Account used to install SmartHub
    • Must be local admin on machine
Supported Web Browsers
  • Google Chrome
  • Chromium-powered Edge
  • Other browsers unsupported*
*Unsupported Web Browsers
Other web browsers may work with SmartHub, such as:
  • Microsoft Edge (legacy)
    • To check your version of Edge, go here.
  • Firefox
  • Safari
These browsers are not officially supported by BA Insight.
Analytics: Elasticsearch Index
Elasticsearch 8.1.2
  • Secured or non-secured Elastic configurations supported.
Note: The Elasticsearch index used for the SmartHub data does not have to be the same instance use for the search index (backend).
Elasticsearch URL:
Elasticsearch Username:
Elasticsearch Password:
Analytics: Kibana Kibana 8.1.2
  • Kibana must be configured to use the above Elasticsearch index.
  • Supports secured or non-secured Kibana configurations
  • For assistance installing Kibana and running as a windows service, see How to Install Analytics Applications.
Kibana URL:
Kibana Username:
Kibana Password:
Haystack Service (Optional) Haystack Service is required for the Questions and Answers feature.
We recommend Haystack be deployed to a separate server/resource so SmartHub performance is not negatively impacted.
NLQ Services (Optional)
  • LUIS (v2 API)
  • RASA v1.9
  • Amazon Lex
  • CLU
Only one NLQ service should be configured.
Supported NLQ/AI Engines:
  • LUIS - Access to a LUIS instance if using the NLQ feature. Support for LUIS is deprecated and will be removed in a future release.
  • RASA
  • Lex
  • CLU
For more information see:
Service Endpoint:
Service Key (LUIS only):
Search Engine
SharePoint Online
SmartHub supports SharePoint Online as a search index.
SharePoint Online URL:
SharePoint Online Username:
SharePoint Online Password:
Network Requirements: DNS
DNS entry for SmartHub site
  • This can be either an internal, or an external (public) DNS entry.
  • Entry can point to VIP / F5 / Load Balancer / other network device.
  • Requests should be routed to IIS on the SmartHub server over the chosen ports.
DNS name / URL for SmartHub:
Network Requirements: SSL Cert SSL Certificate If running SmartHub over SSL (recommended), a signed SSL certificate for that DNS name (or appropriate wildcard cert) is required.
Certificate name:
Passphrase (if required):
Network Requirements: Internal
Internal Network Connectivity
The SmartHub server must have network connectivity to the following:
  • Analytics Index
  • Search Index
  • RASA NLQ Service (optional)
Verified:
  • Elasticsearch service (see Analytics Index, above)
  • Kibana service (see Analytics Index, above)
  • Search Index
Network Requirements: External External Network Connectivity Network connectivity from the SmartHub server to the following Microsoft Azure services is required if you use the service(s):
Verified:
  • AzureAD (optional)
  • SPO / Graph API (optional)
  • LUIS NLQ Service (optional)
