Adding your Smart Previews license
You must add an activated license before you can use SmartPreviews functionality. After you first install SmartPreviews, you will see a banner in the SmartPreviews administration portal that states License is empty.
After adding a license to your SmartPreviews environment, depending on the status of your license, the banner message will display one of the following descriptions:
  • Your <license type> license is valid.
  • Your <license type> Smart Previews license is not valid. It may be corrupted or missing. Please refer to Smart Previews Licensing documentation for more information.
  • Your <license type> Smart Previews license has expired. Please contact the Upland BA Insight Support team to renew license.
  • Your <license type> Smart Previews license will expire in {X} days.
  • Your <license type> Smart Previews license has expired and the product is running on grace period. Please contact the Upland BA Insight Support team to renew license.
Additionally, if you do not have a license configured, users will be able to successfully generate a preview, but will not be able to see the preview content. If a user attempts to view preview content without a license, they will see a message stating "Smart Previews has detected that your product license subscription is invalid. It may be expired, corrupted, or missing. Access to the Smart Previews application has been disabled. Please contact Upland Support to renew your license.".
To add a license to your SmartPreviews environment, do the following:
  1. If you do not already have a license file, obtain one by contacting Upland Support.
  2. Save the license file onto the same server as your Smart Previews administration portal.
  3. If your license is not activated, navigate to the \Upland BA Insight\Smart Previews Import Server\Bin\ folder and open BAInsight.Licensing.Activator.exe. In the license activation window, click Browse and select your Smart Previews license, then select Smart Previews from the drop-down list.
  4. In the administration portal, click License from the left panel.
  5. Click Choose Files, then select your license file.
  6. Click Update License.
  7. If you license was successfully added, you will see a banner message stating "Your <license type> license is valid".
  8. To remove your license, click Remove License.
