Common Scripts and Functions
The scripts have some common functions that are accessible through the Global Host object. To learn more about the common functions, see the table below:
Subtype Function (HOST object) Input Parameters (Type) Return Type Description
Tracing
WriteTrace()
ByVal msg (String) Boolean Writes a trace log that is useful for debugging in the TestBench.
Data Conversion
MyToString()
ByVal msg (Object)
String
Converts all data to a string and handles nulls and dbnull.
URLEncode()
ByVal msg (String) String Encodes the string.
URLDecode()
ByVal msg (String) String Decodes the string.
External Data
RunStringRequest()
ByVal url (String)
ByVal username (String)
ByVal password (String)
String
Executes an HTTP Get operation and returns the string result.
RunStringRequest2()
ByVal url (String)
ByVal cookie (String)
String
  • Executes an HTTP Get operation and returns the string result.
  • This function also supports cookie authentication.
RunByteRequest()
ByVal url (String)
Byte()
Executes an HTTP Get operation and returns the binary result.
RunByteRequest()
ByVal url (String)
Byte()
  • Executes an HTTP Get operation and returns the binary result.
Utility Methods PersistContentValue()
ByVal key (String)
ByVal value (String)
String
  • Saves a value during a session.
  • A session is an enumeration call, item call, or security sync.
GetPersistContentValue() ByVal key (String) String
  • Gets a value during a session that was saved during PersistContentValue.
  • A session is an enumeration call, an item call, or a security sync.
ResolveMimeType() ByVal mime (String) String Resolves a mime type to a file extension.
GetTempFilePath() ByVal extension (String) String Gets a temp file name and uses this name for copying the file for indexing.
GetLockableObject()
Object
  • Gets an object that is global for a content source.
  • This function can also be used for locking.
