Jira Connector Prerequisites
Before you begin the Jira connector deployment, make sure a Jira Administrator can participate in the deployment process to assign the Jira specific tasks.
Required Permission Description
Jira Account
  • A crawling account must be setup in Jira.
    • This account must have READ access to all content to be crawled.
    • The crawling account must be an Administrator account to have access to user and group information and permissions on issues.
Network and Connectivity
Port Comment
HTTP/HTTPS The Jira site must be accessible via HTTP/HTTPS from the server where the connector is deployed
Features Supported Additional Information
Jira Support
  • Cloud version
  • On-premise version
Jira connector compatible with any Jira versions supporting version 2 of Jira REST API.
Jira API token support Jira Cloud
As of November 22, 2025, Atlassian has implemented rate limits on API tokens. As a result, Jira connector for Atlassian Cloud connections must be aware of these changes and monitor header requests to see where they are in regards to limits. For more information, see Rate limiting in the Atlassian documentation.
  • Standard Headers (Jira Cloud)
    • X-RateLimit-Limit: 300 - Max requests per time window
    • X-RateLimit-Remaining: 0 - Requests left in current window
    • X-RateLimit-Reset: 1695720000 - Unix timestamp when limit resets
  • Additional Headers
    • Retry-After: 60 - Seconds to wait before retrying (429 responses)
    • X-RateLimit-FillRate: 5 - Rate at which quota refills
    • X-RateLimit-IntervalSeconds: 60 - Time window for rate limit
Searchable content types Yes All issue types.
Content Update Full and Incremental All BA Insight Connectors support both Full and Incremental crawls, unless noted.
Permission Types Yes
All BA Insight Connectors support fetch ACLs from the source system.
To make items public or restricted to a single user/set of users, use Connectivity Hub.
Required Software
  • BA Insight Advanced Security Module
  • .NET Framework v4.7.2
The Jira Connector requires the BA Insight Advanced Security Module to honor the full security model defined in Jira.
