Run Security Synchronization
The Security Sync task is needed for Connectors that use the Security Mapping function of Connectivity Hub. This task loads User and Group tables and executes the mapping based on the connector configuration.
How to Create the Initial Security Sync Task
To create the initial Security Sync task follow these steps:
  1. Open Connectivity Hub.
  2. Select the Tasks tab.
  3. Click New.. and configure the task:
    1. Scope: Select your SQL connection
    2. Job: Security Sync
  4. Click the Create button and click the Refresh button to show the job status.
    • The job information displays below.
  5. When the job has completed, it should disappear from the Active Jobs tab and appear in Jobs History with "Completed" in the Status column.
Frequency
  • When you are ready to start index for production, schedule this job to run frequently.
  • The frequency depends on the changes made in the source system for security related items such as new accounts, group membership changes, etc.
  • We recommend a minimum of once per day, with more frequent intervals depending upon the impact to AD and the source system.
