SQL Connector Prerequisites
Note! The BA Insight SQL connector is embedded into Connectivity Hub and Connector Framework.
The connector requires only the following user account and application prerequisites:
Administrator Prerequisites
This section assumes the reader has considerable knowledge and experience in the configuration and administration of the following:
  • Your database(s)
  • Strong SQL knowledge and schema knowledge of the database(s)
Required Permission Description
Database Application
  • For OLEDB data sources, like Oracle, the appropriate OLEDB driver is installed for your database
  • READ access to your database and a valid login.
Azure AD Authentication
  • BA Insight does NOT support Azure AD authentication with Azure SQL.
  • The user account used to connect to Azure SQL must be a SQL account.
Azure AD Users and Groups If Azure AD users and groups are used to secure database records, contact BA Insight to confirm your environment is compatible.
Features Supported Additional Information
Application version
Searchable content types Yes All types.
Content Update Full and Incremental All BA Insight Connectors support both Full and Incremental crawls, unless noted.
Permission Types Yes
  • All BA Insight Connectors support fetch ACLs from the source system.
  • To make items public or restricted to a single user/set of users, you can do so within the Connector Framework.
Required Software .NET Framework v4.7.2
