Configure analyzers for specific targets
In Connectivity Hub, you can configure specific analyzers for Elasticsearch, Azure AI Search, and OpenSearch target indices to determine how text is processed, indexed, and searched across search engines. These analyzers break down text into searchable tokens, applying filters such as lower-casing or stemming, and remove irrelevant elements like stop words, ensuring that user queries return accurate and relevant results, regardless of differences in case, tense, or formatting.
Prerequisites
To use a custom analyzer, you must first create one for your index:
For Elasticsearch, see Create a custom analyzer.
For OpenSearch, see Creating a custom analyzer.
For Azure AI Search, see Add custom analyzers to string fields in an Azure AI Search index.
Specify your Analyzer in Connectivity Hub
To specify a custom or predefined analyzer for your Elasticsearch, Azure AI Search, or OpenSearch targets, do the following:
In Connectivity Hub, click Content Sources.
Select the Content Source that you want to apply your analyzer to.
Click the Target Specific tab.
In the Analyzer field, do one of the following:
If you are using a predefined analyzer, select the analyzer from the drop-down menu.
If you are using a custom analyzer, enter the name of that analyzer in this field.
Click Save Changes.
