Toggle the Visibility of UI Elements
Overview
The SearchTools button is a SmartHub component that enables you to toggle on/off the visibility of the UI elements that are inside the HTML <div> tag with the class:
"header-info": <div class="header-info">
By default, the following UI components will be hidden by the SearchTools button:
  • CoveoQuerySummary
  • CoveoSort
  • CoveoResultLayout
  • CoveoResultsPerPage
  • CoveoPager
  • CoveoErrorReport
Change UI Component Visibility
You can change what UI Components are hidden by the SearchTool button by editing the specific HTML page.
  • Update the HTML code inside the container <div class="header-info"> as follows:
    • To enable the SearchTools button add the CoveoSearchTools component to the page:
      • <div class="CoveoSearchTools"></div>
    • By default the SearchTools button hides the UI elements from the "header-info"
      • On page loading the UI elements are hidden
      • Clicking the SearchTools button is required to make the UI elements visible
    • You can change the default state by adding data-default-state="expanded" on the CoveoSearchTools component:
      •  <div class="CoveoSearchTools" data-default-state="expanded"></div>
Configuration
Setting Default Value Description
default-state collapsed
Set's the default visibility of the elements withing "header-info". It can have one of the two values:
  • collapsed: The UI elements are hidden.
  • expanded: The UI elements are visible.
