How to Configure Federated Impersonation
About
Remote Content Sources are search engines which require log-in to the source system in order for users to get back results.
  • The user is prompted to log in to the source system whenever the current search page is configured to show results from a Remote Content Source.
  • You must enable and configure the Federated Impersonation Onboarding Module for the prompt to appear.
  • More information about the Onboarding Modules here.
How to Enable Federated Impersonation Section in Personalization
Use the following steps to configure:
UI Editor
  • The easiest and fastest way to insert and customize Federated Impersonation is via the SmartHub UI Editor.
  • For more information, see How to Use the UI Editor.
Procedure:
  1. SmartHub administrators can simply click the UI Editor link from the SmartHub Administration page.
  2. Click the Select a page link from the top menu.
  3. Select (double-click) an HTML page such as Results.html page.
    1. Below, the Results.html page is shown for sample purposes.
    2. BA Insight recommends you use page and folder to modify. Leave the default files as templates.
      1. Example: Customizations/CustomResults.html. Default Results.html is under the top most SmartHub directory.
      2. See Creating Custom Pages.
  4. Select the Advanced mode from the top right of the page.
  5. Select Advanced settings edit.
  6. Scroll down to line 103 (this may vary), which contains the text SH.UserPreferences.CustomSettings
  7. Change the section SH.UserPreferences.CustomSettings to resemble the code snippet below.
    SH.UserPreferences.CustomSettings = {
        'PersonalizationTabsDefinitions': {
            'FederatedImpersonation': {
                    'label': 'Remote Content Sources'.toLocaleString(),
                    'enabled': true
How Users Authenticate
After Federated Impersonation Onboarding Module is configured, user authentication flow starts as described below.
  1. The user is prompted to authenticate to the Remote Content Source.
  2. The user is then redirected to the authentication page.
  3. After consent is granted, the user is redirected back to the search result page and the query is performed again, this time including the recently approved search engines.
Note: Both user authentication info messages can be changed in the web.config file, located in the SmartHub root directory..
  • For the authentication message see "FederatedImpersonationAuthenticationMessage".
  • For the access denied message see "FederatedImpersonationAccessDeniedMessage".
Changing the label can be done from the value field, but note that {BackendName} is used to display the search engine name configured in Admin UI.
User Personalization - Enable or Disable Remote Content Sources
Go to Personalization → Remote Content Sources.
A user can:
  • Choose if he wants to see results from a specific Remote Content Source.
  • Reset the current authentication token
Available options:
  • Show results from this Content Source
    • The "authentication required" message is displayed in search results and user is prompted for log in (via the Onboarding Module).
  • Ignore results from this Content Source
    • The "authentication required" info result is not displayed in search results and users are not prompted to log in
  • Reset Authentication
    • The reset option resets the authorization token and will make the SmartHub page prompt you to re-authenticate
Admin Management for Remote Content Sources
To see and manage access to Remote Content Sources, go to SmartHub Admin Page > Federated Impersonation.
The administrator can do the following:
  • View the User Authorization status
  • View the account user names that have take impersonation actions
  • View the consent that the user gave regarding authentication
  • Reset consent for users
In the table that appears, various information can be reviewed and actions taken.
  • User Name
    • Name of user who made the action
  • Backend Name
    • Name of the backend name were the user authenticate or not
  • Authorization status:
    • Unauthenticated – The user did not authenticate (yet), the authentication results are returned in search results
    • Access Allowed – The user accepted authentication
    • Access Denied – The user denied authentication
  • Action:
    • Reset status:
      • Return the authentication results in search results
      • Unblock authentication results if it’s blocked by user
  • Reset all selected
    • The same action as Reset status, but for multiple values selected
