Enable users to view saved queries and query history
About the Saved Queries/Query History Feature
  • The Saved Queries component lets user save their favorites queries.
  • The Query History component lets user see their history of queries.
Note the following:
  • DO NOT modify any native HTML page
  • Create a custom version of pages before modifying them. See how to Creating Custom Pages.
  • Leave native HTML pages as templates
  • Native files are overwritten at upgrade time
Configuring Saved Queries/Query History
UI Editor
  • To modify the Saved Queries feature on your HTML page, use the procedure below.
  • The easiest and fastest way to configure saved queries and query history is via the SmartHub UI Editor.
  • For information about how to access the UI Editor as well as who can access it, see How to Use the UI Editor.
Procedure:
  1. SmartHub administrators can simply click the UI Editor link from the SmartHub Administration page.
  2. Click the Select a page link from the top menu.
  3. Select (double-click) the Results.html page.
    1. Below, the Results.html page is shown for sample purposes.
    2. BA Insight recommends you create your own custom page and folder to modify. Leave the default files as templates.
      1. Example: Customizations/index.html, shown below. Default Index.html is under the top most SmartHub directory.
      2. See Creating Custom Pages.
  4. Select the Advanced mode from the top right of the page.
  5. Select the Advanced HTML edit link at the top center of the page.
  6. Place the following code fragment in the desired place for display on the page:
    <div id='saved-query-component'></div>
  7. Click Save changes.
  8. Click Advanced Settings Edit.
  9. Locate the SH.SavedQueries.CustomSettings section.
  10. To access the available SavedQueries settings, click the See Default Settings link in the top right corner.
  11. A new browser tab opens with all available SmartHub module settings.
  12. Search for "SH.SavedQueries" to locate the following code:
Default SavedQueries Settings
SH.SavedQueries.DefaultSettings = {
    EnableSavedQueries: true,
    EnableQueryHistory: true,
    ShowSavedQueriesSortOptions: false,
    ShowQueryHistorySortOptions: false,
    RequiresTracking: true,
    TrackRefiners: true
    ParentContainerSelector: "#saved-query-component",
    TemplatePath: SH.RootLevelURL + "/modules/SavedQueries/templates/template.html",
    ModalPath: SH.RootLevelURL + "/modules/SavedQueries/templates/modal.html",
    GroupId: "Default", //Saved Queries components on different pages will show the same content if they have the same GroupId
    UserProfilePropertyName: "SavedQueries",
    MaxHistoryItems: 5,
    EmailTitle: "Useful query".toLocaleString(),
    EmailBody: "I thought you might find this useful: ".toLocaleString(),
    DeleteSavedQueryWarnMessage: "Are you sure you want to delete this query?".toLocaleString()
  1. Copy and paste the settings code in your custom settings file under SH.SavedQueries.CustomSettings back in your Advanced settings browser tab.
  2. Modify the code as you desire.
  3. Click Save changes.
  4. Click the link Preview <page>.html at the top of the code editor.
  5. Observe the HTML page.
  6. Make any changes and repeat as necessary.
  7. Click Save changes after making changes.
Saved queries and query history settings
Setting Name Default Value Description
EnableSavedQueries
true
  • true - Saved Queries is enabled
  • false - Saved Queries is disabled
EnableQueryHistory true
  • true - Query History is enabled
  • false - Query History is disabled
ShowSavedQueriesSortOptions false When this setting is set to true, sort options will be displayed for the saved queries feature. When set to false, sort options will not be displayed.
ShowQueryHistorySortOptions false When this setting is set to true, sort options will be displayed for the query history feature. When set to false, sort options will not be displayed.
RequiresTracking true
  • true - User query tracking is enabled
  • false - User query tracking is disabled
TrackRefiners true
This setting specifies if refiners are tracked in saved queries:
  • When set to true, saved queries will track the refiners that were applied to the query.
  • When set to false, saved queries will not track the refiners that were applied to the query.
ParentContainerSelector "#saved-query-component" Saved Queries component selector
TemplatePath "/modules/SavedQueries/templates/template.html" Saved Queries template path
ModalPath "/modules/SavedQueries/templates/modal.html" Modal template path
GroupId "Default" Saved Queries components on different pages show the same content if they have the same GroupId
UserProfilePropertyName "SavedQueries" Property name used for storing values
MaxHistoryItems 5 Number of history items
EmailTitle "Useful query".toLocaleString() Email title
EmailBody "I thought you might find this useful: ".toLocaleString() Email body
DeleteSavedQueryWarnMessage "Are you sure you want to delete this query?".ToLocaleString() User Profile service path
Saved Queries Template
  • The SavedQueries template offers several options that can be modified.
  • The file can be found, as specified in Default settings at: <SmartHub_installation_dir>/modules/SavedQueries/templates/template.html.
