Example Campaigns - Birthday Discount Email
Engage campaigns can be as simple or as complex as you like. They can run as one-time events, be part of a series of campaigns, or repeat on a scheduled basis. One common campaign built within Engage is the birthday campaign, designed to send a discount to a customer for their birthday.
You can build a simple birthday campaign using three steps:
An audience query step.
A communication step.
An exit step.
Building a birthday campaign
Open a blank campaign canvas.
Drag your campaign steps onto the canvas.
In the audience step, open the query and use the Anniversary_DaysTo syntax to define your audience, e.g. If you want your email to be sent 28 days before the customer's birthday, where the date resides in a DateOfBirth field on the Individual table, use the query:
Anniversary_DaysTo([Individual].[DateOfBirth]) =28
On the communication step, select your output channel and define the properties, e.g. if using Upland Adestra to send your birthday communications, select the Adestra channel and the corresponding creative template.
Connect the communication step outputs to an exit step to exit audience members from the campaign and make them eligible for the campaign next year.
Set the campaign to run on a daily schedule to pick up new audience members as the Anniversary_DaysTo value changes.
