ONE_IN_N
When used within a query the function produces a recordset that contains a sample of records. When used within a virtual field the function will return True for records that match the criteria given and False for those records that do not.
ONE_IN_N ( <table_name or expression>, <nvalue>, <offset> )
  • table name or expression: Can be either a table name, or an expression (a query string or another query domain function) resulting in a recordset.
  • nvalue: A number representing the systematic frequency at which to sample records
  • offset: A number representing the record at which to start sampling, as read from the first record in the table
Example: Create a query at the Individual level to return every third individual starting with individual number 2
ONE_IN_N(Individual,3,2)
