STAT_SUM
This function returns the same value for every record in a table. It allows the resultant summary statistic for a field to be compared against each individual value for the field. In this case the summary statistic returned is the sum.
STAT_SUM ( <field_name>[, <from_value>[, <to_value> [, <sample_size>[, <filter_query>]]]] )
  • field_name: The name of the field to calculate the statistic on.
  • from_value: The lowest value for the field to include in the calculation of the statistic. The default is the minimum value in the field.
  • to_value: The highest value for the field to include in the calculation of the statistic. The default is the maximum value in the field.
  • sample_size: A number representing the number of records to include. Can be 1, 10, 100 or 1000. The default is 1.
  • filter_query: A query string representing the domain of records to calculate the statistic for.
Example: Create a query at CUSTOMER level to return customers whose income is more than 5% of the sum of incomes for all customers.
[CUSTOMER.INCOME] >(([CUSTOMER.INCOME]/STAT_SUM( [CUSTOMER.INCOME])))*100 > 5
