Set a Task as a Milestone
Through any project work planner, Eclipse users can easily define milestones.
To set a task as a milestone
- Open the required work planner.
- Click the action arrow next to the task you need to make as a milestone.
A drop-down menu is displayed.
- From the drop-down menu, click Open.
The Task dialog box is displayed.
- Open the Properties tab.
- Select the Is Milestone check box.
- Click OK to save the changes made.
Note: Before closing the work planner, always make sure you click Save after you take all necessary actions.
