Ellipse stencil
Ellipse stencils can be used to draw ellipses on workflow processes in the Process Designer. These stencils are used to provide visual organization in the Diagram pane and do not have any function in a published workflow process.
In the Process Designer, click the Ellipse stencil and move it to the desired location in the Diagram pane using a drag-and-drop operation.
Configuration
1. To access stencil properties, in the Diagram pane of the Workflow Designer, perform one of the following:
- Double-click an Ellipse stencil.
- Right-click an Ellipse stencil and select Properties.
- Select an Ellipse stencil and press the F4 keyboard shortcut.
2. Specify a Fill Color, Border Color, ellipse Opacity, and Border Thickness.
3. Click OK.
