URL control properties
Once a URL control has been added to a form, you can configure it using the options on the Properties tab.
ID: The URL control ID. The ID is automatically assigned when a URL control is added to a form. The value of this field cannot be edited.
Name: A name for the URL control. This name is used to identify the URL control in other forms.
URL: The URL of the website. Users can click this URL to navigate to the specified website.
Link Text: The text for the URL. This text will appear as a link on the web form.
Tab Order: The sequence in which a field will be selected when Tab is pressed. For example, if the tab order for a field is set to 3, when Tab is pressed for the third time, that field will be selected.
Edit Rules: Opens the Edit Rules window where you can configure conditional rules for the control. See Conditional rules for more information.
