About Billing Component Mapping Option
You can map property values to column names in the Billing component. This allows the mapped values to be used, for example, in templates. Otherwise, any changes or additions to column are made within the HP CR Archive database. This option allows you to map specific values to individual columns in the Billing Properties.
Mapping a value to a billing column name
To map a value to a Billing Column Name:
  1. In the HP CR Server Administrator, select Components and double-click the Billing component. The Billing Properties dialog box appears.
  2. Select the Configuration tab.
  3. Make sure Enable collection of data is selected.
  4. Select a column name you want to map a property and click the Map button. The Map Column Value dialog box appears.
  5. Click ... and select the property of interest.
  6. Click OK and click OK again.
Enabling Billing Component
Configuring Billing Component
