About Modem Server
The Modem Server enables theHP Capture and Route Server to communicate with fax boards throughout your company's network. The Modem Server is part of the server installation. It should be installed on the server system if you have installed fax boards on that system. Also, it should be installed on other systems with fax boards that communicate with the server.
You can install a Modem Server on any system in your network that has Windows 2003/2000 and a fax board.
Local Modem Server and Remote Modem Servers
If a Modem Server is installed on the server, this system is referred to as the local Modem Server. If a Modem Server is installed on a different system than the HP CRserver, this server is referred to as the Remote Modem Server.
You are required to install fax driver software on the system that has the modem server installed on it.
Multiple Remote Modem Servers
If you have multiple Remote Modem Servers, you can manage them all with one Telco connector. If you want to manage them with more than one Telco connector, you need to purchase a license for each additional Telco connector you want to add.
Tip: HP CR supports several types of Telco configurations. These Telco configurations help you meet the requirements of your messaging environment.
About Telco Connector
Modem Server Telco Connector Benefits
Managing Fax Properties
Adding a Telco Connector
