About SNMP v3
SNMP (Simple Network Management Protocol) v3 provides secure access to devices by authenticating and encrypting data packets over a network. The HP CR server supports SNMP v3 for devices configured with your server.
Note: The Server Administrator SNMP v3 connection settings must match the device’s SNMP v3 settings.
To enable SNMP v3
For HP OXPd devices
  2. Expand Devices on the Server Administrator tree.
  3. Select the appropriate device group.
  4. Select the appropriate device in the Devices details pane. The Properties dialog box appears.
  5. Select the Connection tab.
See the Properties for HP OXPd device dialog box example below.
  1. Select the Enable SNMP v3 check box. The SNMP v3 area becomes active.
  2. Specify a username in the Username box.
You can specify the following protocols.
  • Authentication and Privacy
  • Authentication only
  1. Specify an authentication password in the Auth Password box.
  2. Specify the authentication protocol type in the Auth Protocol box
  3. Specify the privacy password in the Priv Password box.
  4. Specify the privacy protocol in the Priv Protocol box.
For Ricoh devices
Modifications were made to the Properties for Ricoh > Connection dialog box. Administrators can specify the following parameters.
  • Device Username
  • Device Password
  • Remote Password
In addition, a description of the device is provided during a device query; for example, Android or Xlet. The query entails a call to an IP address to verify the device exists and is valid. No further setup is required.
For Xerox devices
Modifications were made to the Properties for Xerox > Connection dialog box. Administrators can specify the following parameters.
  • Device Username
  • Device Password
More device modifications
HP CR server configuration supports the latest Extensible Interface Platform (EIP) v4.x for Xerox devices. The software platform allows us to continually create document management solutions that meet your workflow requirements.
See the Supported Devices List for more information.
Button Properties > Scan Settings
A new Duplex Format setting has been added to Scan Settings. In addition, the Preview option located on the General tab has been renamed to Scan Preview and moved to Scan Settings.
