About Test Message
Administrators can use Test Message to send test messages using the HP Capture and Route Server Administrator. Because Test Message generate real messages that originate on the server, you do not need a client application (like Microsoft Outlook installed on the server) to send test messages.
Note: You can use Test Message only on servers with fax capability.
Before you begin
Before using Test Message, you must set up the connector (Telco, Exchange, Notes, SMTP, etc.) that will deliver the fax to its final destination.
Sending a test fax using Test Message
  2. On the Start menu, click HP Capture and Route > HP Capture and Route Server Administrator.
  1. On the console, expand the Server Administrator tree.
  2. Right-click Messages. and select New > Test Message. The Test Message dialog box appears.
  3. Type an address in the Sender Email box.
  4. In the Recipients section, click the Add button.
  5. Select the Destination type: Email, Fax, Printer, or Folder.
  6. Click Next.
  7. Specify the appropriate recipient information in the boxes provided. This will vary based on the destination type selected.
  8. Click Finish. The recipient is listed. To add another recipient, click Add and repeat Steps 6 and 7.
  9. Type a subject and/or comments in the boxes provided.
  10. In the Attachments section, click the Add button.
  11. Find the document you want to attach, select it and click Open.
  12. Click Deliver.
  13. Verify that the message was delivered to the correct destination.
Troubleshooting failed faxes
When troubleshooting fax failures, it is beneficial to use a test message to quickly send a fax and test the server. After you send a fax using Test Message, you must go to the destination and verify that the fax was delivered. Verification is necessary since the server can only confirm that the fax was delivered. It cannot guarantee that the fax printed on the recipient's fax machine or reached the email account of the recipient.
If the fax journal indicates that the fax was delivered successfully, but the fax does not reach the intended recipient, troubleshoot the situation in the following order.
  • Check the destination address in the Test Message to make sure you are looking at the appropriate destination.
  • If the destination is correct, check that the fax machine, mail server, or other device is functioning correctly.
