Adding DMS Connector
The DMS connector routes documents from the server to a company's document management system (DMS). Before adding a DMS connector, review DMS connector requirements.
To add a DMS connector
  3. Right-click Connectors. Select New Server connector > DMS. The License dialog box appears.
  4. In the License text box, type the connector license.
  5. Click Next. The Server Address dialog box appears.
  6. Click Next. The Display Name dialog box appears.
Alternately, if you want the connector to run on a remote server, click Remote Server and type the server name. Click Next.
  1. In the Name text box, type an appropriate name.
  2. Click Next. The DMS Type dialog box appears.
  3. Select a DMS from the drop-down list.
  4. Click Next. The Congratulations dialog box appears.
  5. Click Finish. The new DMS connector is listed in the Connector details pane. Users can route documents to their configured DMS.
Note: When using a Remote DMS connector, the DMS client application must be installed and configured on the remote system.
About DMS Connector
DMS Connector Requirements
Supported Document Management Systems
DMS Libraries
