Cover Page Data Source
The following table lists the source of cover page data.
Connector Type |
Cover Page Data Source |
Filescan |
Cover page information for senders and recipients comes from the control file placed in the Filescan folder. Filescan has keywords that are used for standard information, such as the recipient's name and fax number and the sender's name and email address. Regular cover page variables can also be placed in the control file for any additional information that should appear on the cover page. If regular cover page variables are used, they must be present on the cover page template specified in the control file. Otherwise, the information will not appear on the cover page. |
| HP CR End User Clients | Sender information comes from the user's properties in Active Directory and can include any of the information for which a sender variable is supplied in the cover page template. |
SMTP |
Sender and recipient information comes from the control file sent as an attachment with the message. There is a set of keywords that can be used in the SMTP control file, but regular SENDER cover page variables can also be used. |
Using Cover Page Template Variables Guidelines
