Creating a Database
Before you create a Database connector, you must create a database with a table to store message data. This table must include the MessageContents and MessageBodyPath required fields.
To create a database for the Database connector
  1. Create a SQL database.
  2. Create a table in the database where you want to store the message data.
  3. Add the following required fields to the table.
    • MessageContents
    • MessageBodyPath
Note:  Ensure the field names are spelled correctly. No data is recorded if the field names are inaccurate.
  1. Save and close the database.
Database connection string guidelines
You can use the following guidelines to create a connection string for your database.
  • Create the connection string using the following format.
  • keyword=value;keyword=value;keyword=value
  • Use appropriate keywords for the type of database you will use. See the examples listed below.
Examples of SQL database connection strings
In most cases, the server will connect to your SQL database using a trusted connection. However, if you modify this setting so that the server connects to your SQL database through SQL security protocol, you need to create your connection string using a different format.
SQL database using a trusted connection (default)
For a trusted connection, the connection string should contain the provider, data source, initial catalog, and integrated security settings. This information tells the server the type of database you are using, the location of the database, the name of the database, and the method for connecting to this database.
The following string shows you the general format you should use when you create a connection string for a trusted connection.
Provider=sqloledb;Data Source=ServerName;Initial Catalog=DatabaseName;Integrated Security=SSPI
This is an actual example of a connection string for a trusted connection.
Provider=sqloledb;Data Source=Mercury;Initial Catalog=FaxArchive;Integrated Security=SSPI
SQL database using SQL security
For SQL security, the connection string should contain the provider, data source, initial catalog, user name, and password. This information tells the server the type of database you are using, the location of the database, the name of the database, and the username and password of the user account.
Note: The user name and password are required so that the HP Capture and Route Server can gain access to the database.
The following string shows you the general format you should use when you create a connection string if you have enabled SQL security.
Provider=sqloledb;Data Source=ServerName;Initial Catalog=DatabaseName;User Id=Username;Password=Password
This string shows you an actual example of a connection string that you might use if you enabled SQL security.
Provider=sqloledb;Data Source=Mercury;Initial Catalog=FaxArchive;User Id=IT_Administrator;Password=7h3k62br
About Database Connector
Database Connector Requirements
Adding a Database Connector
Database Connector Fields List
