DMS Routing Sheet Variables Lists
The following table lists the DMS variables that are available for Routing Sheets. For a list of other variables that can be used in Routing Sheets, see List of template variables (in alphabetical order).
Note: A recipient template variable to be used on the Routing sheet must look like: %DMS_xxxx.1% for the xxxx template variable of the first DMS recipient and %DMS_yyyy.2% for the yyyy template variable of the second DMS recipient and so on.
Additionally, all DMS Custom fields (that you can view in a default document profile dialog in a DMS Connector's admin extension) are also published in the Routing Sheet using the following naming scheme.
%DMS_CF_InternalFieldName.1%
%DMS_CF_InternalDMSFieldName_DISPLAY.1%
Variable |
Description |
Supported DMS |
%DMS_MD_DOCUMENT_ID.1% |
The unique internal DMS ID of the document |
%DMS_MD_DOCUMENT_NAME.1% |
Document name or title. For example: Quarterly Report |
%DMS_MD_DOCUMENT_FRIENDLY_NAME.1% |
The friendly name of the document which usually consists of the title and document’s number |
%DMS_MD_DOCUMENT_NUMBER.1% |
Internal unique DMS document number |
%DMS_MD_DOCUMENT_COMMENTS.1% |
Comment for the document |
%DMS_MD_DOCUMENT_VERSION.1% |
Version number for the document |
%DMS_MD_DOCUMENT_LIBRARY.1% |
Name of the library where the document is being routed to |
%DMS_MD_DOCUMENT_FOLDERID.1% |
Unique internal DMS ID of the document’s folder |
%DMS_MD_DOCUMENT_FOLDERID_DISPLAY.1% |
Name of the DMS folder as shown in DMS Client |
%DMS_MD_DOCUMENT_CLIENT.1% |
Client ID field of the document’s profile |
%DMS_MD_DOCUMENT_CLIENT_DISPLAY.1% |
Full display name of the Client's field |
%DMS_MD_DOCUMENT_MATTER.1% |
Matter ID field of the document’s profile |
%DMS_MD_DOCUMENT_MATTER_DISPLAY.1% |
Full display name of the Matter's field |
% DMS_MD_DOCUMENT_CLASS.1% |
Document's Class ID field |
%DMS_MD_DOCUMENT_CLASS_DISPLAY.1% |
Full display name of the document's Class field |
%DMS_MD_DOCUMENT_SUBCLASS.1% |
%DMS_MD_DOCUMENT_SUBCLASS_DISPLAY.1% |
Full display name of the document's Subclass field |
%DMS_MD_DOCUMENT_AUTHOR.1% |
Document's Author ID field |
%DMS_MD_DOCUMENT_AUTHOR_DISPLAY.1% |
Full display name of the document's Author field |
%DMS_MD_DOCUMENT_TYPE.1% |
Document's Type ID field |
% DMS_MD_DOCUMENT_TYPE_DISPLAY.1% |
Document type's full display name |
About Custom Variables
Recipients and Distribution Lists Variables
