About Prompts
The Server Administrator can create prompts for HP CR Client users. When creating a Distribution, you can assign prompts to it. Later, when you use the Distribution, the prompts are triggered. You need to provide specific values as requested and then click OK to move to the next prompt, if any. The Distribution routing and delivery cannot continue until appropriate values are supplied.
Note: HP CR Client users can also enable prompts to enter important metadata information when creating a message.
For example, you might use a prompt to request a Document Name for profiling it into a document management system.
Setting Message Options
