Configuring Document Stamps
You can configure Document Stamps for specific groups or rules by using the Server Administrator > Configuration or Rules node.
Document stamps for specific groups
To configure document stamps for specific groups
  1. Launch the Server Administrator.
    • On the Start menu, click HP Capture and Route > HP Capture and Route Server Administrator.
  1. Expand the tree view, and click Configuration > Groups.
  2. Right-click the group of interest and select Properties. The Groups Properties screen appears.
  3. In the Document Stamps tab, select Enable members of this group to select the specified Document Stamps.
  4. Select the document stamp(s) of interest from those listed and click OK.
Note: In the HP CR Client, Document Stamps are available from Client Preferences and Message Options.
Document stamps for rules
You may want to consistently apply document stamps to a particular kind of message or distribution. To do so, you identify the specific Document Stamp as an Advanced Custom Core Property when creating the rule.
To configure a rule to apply a Document Stamp to all emails
  2. Expand the Rules node and select Outbound.
  3. Right-click Outbound and select New > Rule. The Create New Rule screen appears.
  4. Click Add. The Add Rule Criteria screen appears.
  5. Select Destination is an e-mail address and click Next.
  6. In the Items to Match screen, select the is radio button and enter * in the following text box to have this rule apply to all email messages.
  7. Click Add and then click Finish.
  8. Returning to the Specify the Criteria for this Rule screen, click Next.
  9. In the Specify actions to take for this Rule screen, click Add. The Add Rule Action screen appears.
  10. Select Route to Connector and click Next.
  11. The Route to Connector screen appears. Select Filescan on the Server from the Route to Connector drop-down menu.
  12. Select PDF as the final message delivery format from the Document Delivery Format drop-down menu.
  13. Click the Advanced button. The Advanced Routing Options screen appears.
  14. Click the Custom Properties button. The DMS Rule Properties screen appears.
  15. Make sure Core Properties is selected and click Add. The Core Property screen appears.
  16. In the Name field, enter prDocumentStampName and in the Value field enter the name of the Document Stamp of interest.
  17. Click OK, OK and Finish.
  18. Returning to the Specify actions to take for this Rule screen, click Next.
  19. Click Next and then Finish.
  20. The Specify a name for this rule screen appears. A default rule name including all your choices appears. You can change this name as needed.
  21. Select Finish.
About Document Stamps
Creating a Document Stamp
