Configuring T.37 Fax Connector
You can configure the T.37 Fax connector by using the Server Administrator > Connectors node.
To configure the T.37 Fax connector
  • On the Start menu, click HP Capture and Route > HP Capture and Route Server Administrator.
  1. On the console, expand the Server Administrator tree.
  2. Click Connectors to list all connectors.
  3. Double-click T.37 Fax connector to open the Properties dialog box.
  4. Click the Options tab.
  5. In the Fax domain name box, verify that the domain name is correct. The format for the domain should be "@faxdomain.com" or "user@faxdomain.com".
  6. In the Email Filter box, verify you have the correct email filter. The default filter is %prDestinationLocalized%. The format of the filter must match the format that is acceptable at the destination. For example, when sending jobs to a fax domain, the @ sign should be removed. For more information on acceptable formats you can use, check with your service provider.
The following table lists the other variables you can use.
Variable
Definition
Example
%prDestinationLocalized% (mandatory)
Destination fax number; for example, 978 555 1212.
Note: Check with your service provider about the validity of the format of the destination fax number.
%recip_name% (optional) Name of the fax recipient /TO=%recip_name%
%sender_name% (optional) Name of the fax sender /FR=%sender_name%
%prBillingCode% (optional) Billing information for the server or the service provider. /AC=%prBillingCode%
  1. In the Subject box, type a descriptive subject for your message. See also, Configuring subject and comments of a fax message.
  2. In the Message body, type a brief message. See also, Configuring subject and comments of a fax message.
  3. Click Advanced to show the Advanced options.
  1. Select from the other options in the Options to be performed on E-mail address after substitution and the Remove the following characters sections.
Note: In the Options to be performed on E-mail address after substitution section, the Encapsulate in Quotes option is selected by default.
  1. Click OK to save your changes.
Limitations
When sending a fax using the T.37 connector, understand that some symbols can interfere with the routing of emails in general. Therefore, avoid the following symbols.
Symbol
Description
To: The "To:" line (as part of the @Mail.com address)
@ Ampersand ("at" symbol)
~ Tilde
% Percent
( Left parenthesis
) Right parenthesis
; Semicolon
> Greater than
< Less than
^ Carat
[ Left bracket
] Right bracket
! Exclamation point
\ Black slash
/ Forward slash
. Period
About T.37 Fax Connector
Creating a T.37 Fax Connector Outbound Routing Rule
Configuring a Fax Message Subject and Comments
