WorkSite Web Extensions
For Administrators using WorkSite Web v10.0.x On-Premises configurations only
Note: These instructions only apply to Administrators of WorkSite Web less than or equal to v10.0.x on-prem configurations. These instructions cannot be used for WorkSite Web on-prem greater than v10.0.x or cloud configurations. Verify what version you have before proceeding.
The HP CR WorkSite Web Extensions supports the following integrated functionality.
  • Sending documents to WebApps via the Send to HP CR option
  • Import with Copied Profile allows to modify the properties of a document
  • Upload the document to the folder using the Upload Scan
Note: WebApps must be configured to use HTTPS.
Configuring WorkSite Web Extensions
To configure the WorkSite Web Extensions
Prerequisite: Install the Server and WebApps Client.
  1. Install the Desksite client on the server.
  2. Launch the Server Administrator.
  3. Go to Connectors node, right-click and select Worksite as a new Connector.
  4. Provide the WorkSite Server Name and login credentials and click Finish to add the Worksite connector.
  5. Verify the Worksite connector is added to the Connectors list.
  6. Go to the Configuration > WebApps > Default. The Default Profile Properties dialog box appears.
  7. Select the Features tab.
  8. Click Add and select WorksiteWebExtension. The WorksiteWebExtension Feature Properties dialog box appears.
  9. Provide the WebApps URL as https://arservername/hp cr , make sure the server name and hp cr is lowercase.
  10. Provide the WorkSite Web URL as https://worksiteservername  in the WorkSite URL field.
  11. Provide the name of the WorkSite Server in the Worksite Server field.
  12. Click on the Generate Extension Configuration File and save the configuration zip file.
  13. Click OK to add the WorksiteWebExtension.
Installing WorkSite Web Extensions
To install WorkSite Web Extensions
  1. Place the WorkWebExtension zip file generated on the server in the WorkSite server folder: [WorkSite Install Folder]\web_module\ext\installed.
  2. Restart WorkSite services
Testing WorkSite Web Extensions
  1. Launch the WorkSite Web using the URL [https://worksiteservername]
  2. Right-click on the document in the workspace to see the extension options.
  • Send to HP CR
  • Import With Copied Profile (Pre-requisite: Install the Server and WebApps Client)
About WebApps
MyFiles
AddressBook Integration
Customizing WebApps Link
