About Distributions
A Distribution is a defined group of one or multiple recipients and associated Routing Rules. With Distributions, you can access and view your personal and subscribed distributions.
The My Distributions tile lists your Personal and Public distributions created in the HP CR Client. My Distributions are known as Personal Distributions. With My Distributions, you can perform the following tasks.
  • Create distributions.
  • View or edit distribution properties.
    • Select the distribution and use the Properties button in the toolbar to view and edit the properties.
The Subscribed Distributions tile lists the Public Distributions of other users that you are subscribed to. With Subscribed Distributions, you can perform the following tasks.
Note: Distributions are available on the Embedded Device Client display panel. Personal Distributions require authentication. By default, Public Distributions do not. With either, you can use a single MFP button to instruct the server to send your document to the recipients in your selected distribution.
About Messages
Sending Messages
Viewing a Distribution
Modifying a Distribution
Creating a Personal Distribution
Creating a Favorite Distribution
