Using a Routing Sheet with Microsoft SharePoint
The Create New Routing Sheet option creates a Routing Sheet within your Microsoft SharePoint document library. You can use the Routing Sheet to scan hardcopy documents from any scan-enabled device. The documents are submitted to the server for processing and routing to the Microsoft SharePoint repository according to the Routing Sheet instructions.
Open Microsoft SharePoint and go to the document library where you will route your inbound documents.
Click Upload. Select the Upload Scan option.
On the Upload Scan page, enter the Name, Title, and document Format for your scan. This is the destination information for the inbound document within the Microsoft SharePoint document library.
Click Save. HP CR Client opens.
Select the Create New Routing Sheet option.
A Routing Sheet is generated with the destination information from Step 3, and opens in your default PDF viewer.
Print the Routing Sheet and use it for scanning hard copy documents. Optionally, save it for reuse.
About Extensions for Microsoft SharePoint
Creating a Scan Reservation in Microsoft SharePoint
Opening a document in HP CR Client
