Using Document Sets for HP CR Client Users
A Document Set is a set of documents that are related to specific workflow processes. Document sets can be used in a variety of ways. See examples below.
  • HR New Hire Document Set – all documents related to the hiring process of a new employee
  • Legal Case Document Set – all documents related to a client’s legal matter
  • Loan Document Set – all documents related to a client’s loan application
  • Hospital Patient Document Set – all documents related to a patient’s care
Understanding the Document Sets workflow
Administrators create document sets based on your company’s processes. Document sets is an internal label that can be renamed to be more descriptive and reflect your specific workflow process. Contact your Administrator to find out if the document sets label has been renamed.
You will select the categories and form types associated with a particular document set and capture the appropriate properties by creating Scan Reservations or Batch Routing Sheets.
Using the Scan Reservation or Batch Routing Sheets created, you scan the documents that are delivered by the server based on the workflow rule(s) established by the Administrator.
Note: Scan reservations are considered personal distributions. You cannot view or execute another user's personal distributions only your own at a device.
Loan Document Set Example
The Loan Document Set will be used as an example in the next series of steps for illustrative purposes only and may not reflect your specific workflow configuration. Form fields and form type properties are used to uniquely identify the documents associated with a process.
In the Loan Document Set scenario, there is a Home Loan category and the following form types.
  • Mortgage Application
  • Credit Report
  • Employment Verification
  • Checking Savings Bank Statement
  • W2 Wages
Categories are created to organize the form types associated with a document set. Form types are placeholders that represent the forms that will be scanned at a device. The forms are routed by the server based on the rules created by your Administrator. The Scan Reservations or Batch Routing Sheets created contain the following distribution/destination information.
  • Document Set Category
  • Form Types
  • Form Fields - used to identify and classify the form types.
  • Form Field properties
  • Form Type properties
Properties are used to provide additional information about form fields and form types.
Using Document Sets for Device Client Users
