Invoice Extraction stencil
The Invoice Extraction stencil is used to automatically extract information from invoice type documents using a machine learning AI model. When this stencil is used, the document does not have to go through OCR or be trained.
After going through the Invoice Extraction stencil, each data field will be highlighted on the document as follows:
  • Green = 80% or higher confidence
  • Yellow = 50% - 80% confidence
  • Red = under 50% confidence
Note: Each document that is processed through this workflow stencil will decrement your page count license by the number of pages displayed.
All extracted data fields will be available on the Journal tab in Document Properties. See View document properties for more information.
Available connections
There are two outgoing connections from an Invoice Extraction stencil: green if the invoice extraction was successful and red if the invoice extraction failed.
Configuration
  1. To access stencil properties, double-click an Invoice Extraction stencil. Or, right-click an Invoice Extraction stencil and select Properties.
  2. In the Display Name box, enter a name for the stencil. The display name will be the name of the folder representing the workflow step in the Document Panel.
  3. Configure the stencil using the following tabs:
  4. Click Save.
