Rename Document stencil
The Rename Document stencil is used to change the name of a document via the workflow.
Available connections
There are two outgoing connections from a Rename Document stencil: green if the document was renamed successfully and red if the document renaming failed.
Configuration
  1. To access stencil properties, double-click a Rename Document stencil. Or, right-click a Rename Document stencil and select Properties.
  2. Select the type of document renaming you want to perform during the workflow step. The following options are available:
  3. Click Save.
Add formatting to a document name
You can specify formatting rules for document names. If the configured conditions are true when a document is processed through the stencil, then the formatting is applied. Formatting rules can be used to:
  • Change case
  • Insert a prefix
  • Append a suffix
  • Insert characters
  • Remove characters
  • Replace characters
Add a formatting rule
  1. Click Add Formatting.
  2. Enter a name for the formatting rule in the Name box.
  3. Select an option from the If the value drop-down box. The following options are available:
    • Starts With: The document name starts with the characters entered in the box.
    • Ends With: The document name ends with the characters entered in the box.
    • Contains: The document name contains the characters entered in the box.
    • Matches Regex: The document name matches the Regex entered in the box.
    • Length: The document name is a particular length of characters. Select an operator from the drop-down menu, then enter a character length in the box.
  4. Select the Ignore Case check box to ignore the case of document names.
  5. Select an option from the Then drop-down box. These will be applied to the document name when the If the value condition above is met. The following options are available:
    • Change Case To: Changes the case to either uppercase or lowercase.
    • Prefix With: Adds text to the beginning of the document name.
    • Suffix With: Adds text to the end of the document name.
    • Insert: Inserts text within the document name. Specify where text should be entered in the At position box. Specify a length in the Until the length box. The text will be repeated in the position until the length is met.
    • Remove: Removes the specified number of characters. Specify where characters should be removed in the At position box. Specify a length in the Until the length box. Characters will be removed from the position until the length is met.
    • Replace: Replaces part of the document name with new text. Specify the text you want to replace in the box, then enter the new text in the With box.
  6. Select Stop processing further formatting to stop processing subsequent formatting rules once a rule has been applied.
  7. Click Add Formatting to add additional formatting rules if necessary.
Test formatting
You can see how the current set of formatting rules will be applied to a document name.
  1. Click Test.
  2. Enter a value then click Apply Formatting.
  3. You will be able to view the status and output for each rule and the final formatted value.
  1. Click Close to return to the rule configuration.
