Detect Signature stencil
The Detect Signature stencil uses a machine learning AI model to determine if a signature exists on a document.
Note: Each document that is processed through this workflow stencil will decrement your license by the number of pages/units displayed. See Workflow stencils for more information.
Available connections
There are four outgoing connections from a Detect Signature stencil:
- SignatureFound: A signature was detected on the document with high confidence. If a signature is detected, it is highlighted on the document in green.
- SignatureSuspicious: A signature was suspected on the document, but the engine had low confidence that it read the data correctly. If a suspicious signature is detected, it is highlighted on the document in yellow.
- SignatureMissing: A signature was not detected on the document.
- Failed: An unexpected error occurred preventing the signature detection from completing on the document.
Configuration
- To access stencil properties, double-click a Detect Signature stencil. Or, right-click a Detect Signature stencil and select Properties.
Adjust the Confidence Threshold as needed. If the signature is returned with a confidence above this threshold, it is considered a valid signature. If it is returned with a confidence below this threshold, it is considered suspicious.
- Click Save.
