OCR+ stencil
The OCR+ stencil is used to automatically perform advanced Optical Character Recognition (OCR) on documents using a machine learning AI model. The advanced functionality can also convert handwritten text into machine-readable text.
Note: Each document that is processed through this workflow stencil will decrement your license by the number of pages/units displayed. See Workflow stencils for more information.
Available connections
There are two outgoing connections from an OCR+ stencil: green if the OCR was successful and red if the OCR failed.
Configuration
There is no configuration necessary for an OCR+ stencil.
