Printer driver properties and advanced settings
It is not normally necessary to change the OL Connect Send printer driver's properties or advanced settings.
Most of these settings (e.g. Output Destination, Stapling, Jogging) will not have an effect, unless the print service supports them. Ask your print service provider which features can be used when printing a document.
Nevertheless, a few settings are important to the proper functioning of OL Connect Send. It is recommended not to change them, or if they were changed, to revert them to the default settings, listed below.
Properties:
Device settings tab:
- Font Substitution Table: all fonts are set to
<Don't Substitute> - Minimum Font Size to Download as Outline:
1 pixels
To open the Properties: in Window's Devices and Printers control panel, right-click the printer and select Printer properties.
Advanced settings:
Paper/Output:
- Collated: checked
Graphic:
- TrueType Font:
Download as Softfont
- TrueType Font:
Document options - Postscript options:
- PostScript Output Option:
Optimize for Portability - TrueType Font Download Option:
Native TrueType
To open the Advanced settings: in Window's Devices and Printers control panel, right-click the printer and select Printing preferences; then click the Advanced button.
