0.010/29/2019
FAQ-1232: Error - Numeric Field Overflow
Description
Error: Numeric Field Overflow
We have an MS Excel database file with a field called "Last Name". When the file is created (printed), some of the records show this Error
Why? How can we correct this?
Summary:
This error may be caused by the database engine scanning a set number (mostly 25) of records to determine the datatype of a column.
Contents
The fields that cause the error are -for various reasons- erroneously interpreted as 'double' or 'long', whilst the first records were set to f.i. 'text' as datatype.
The SolutionThe following procedure may solve the issue: (in case the datatype must always be 'text':)
Save the database as .txt file (tab delimited) and re-open this .txt file in MS Excel:
Follow the Text Import Wizard and in step 3 (of 3) set the Column data format to 'text' (in the column(s) where the error happened, or, to prevent the error genericly: for all columns with 'text'data).
Alternatively you can insert a dummy record before the first record where the numbers should be in the database.
