0.010/29/2019
FAQ-1239: Offending Command - Get
Description
Offending Command: get
Summary:
Problems with the 'Get' command are often caused by corrupted or incorrect imported graphics.
Contents
Try opening all the graphics from your page using the application used to created then and simply resave the files. Then update the links in the page and try printing again.
Switching to another format (like saving all TIFF files as EPS's) can help to solve the problem.
Undefined errors
A PostScript error "undefined" error, offending command "get" is generated by the RIP whenever it tries to read data from a dictionary, which are not there. Those dictionaries can be sent along the file by the application, they can be part of an EPS or PS-file but they can also be one of the RIP-dictionaries. So if this error happens with a lot of similar jobs, you can eliminate it by reinstalling the software of the RIP.
The same error can also show up in Scenicsoft Preps 4.0 when PostScript level 2 in-rip separations are activated and one or more process colours are not selected for output. This error is fixed in Preps 4.02.
ATM Deluxe
ATM Deluxe can also cause "get" errors. Switch off "font substitution" in the ATM Deluxe settings.
