0.010/29/2019
FAQ-1252: Offending Command - nostringval
Description
When printing I get PostScript Error: invalidaccess. OffendingCommand: --nostringval--
Printing a PDF to file, in order to re-distill it, also fails.
Contents
There is no solution for this because the PDF may be a secure document.
To check this, open the PDF in Acrobat and see File -> Document Info -> Security.
If "Changing the Document" is set to "Not Allowed", then converting the PDF to (Encapsulated) PostScript will fail.
The SolutionRemove the security from your PDF
