At installing I get error 1935
This is a problem when installing the MSXML component of the installer.
The Solution
Install the MSXML 4.0 installer and run this.
If this doesn't solve this issue, can you send us the log of the installer:
* Open a command prompt
* Navigate to the folder containing the setup.exe
* Type the following, including quotes: setup.exe /V"/L log.txt"
* Follow the steps in the installation wizard until it fails
The file log.txt should now contain more detailed error information.
