I am getting an "Reserved error (-5402); there is no message for this error. [OK]" error when opening a database.
When opening the database, PrintShop Mail uses the schema.ini file located besides the database. In that schema.ini file the encoding definition is set incorrectly.
CharacterSet=0
Remove this entry or define the correct encoding table for this database.
