Get All Operations
Returns a list of all the workflow operations actively running on the Server.
Request takes no content, and on success returns a response containing a JSON Operations List of all the actively running operations.
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Response
Success
200 OK |
JSON Operations List of all the actively running operations in Server | application/json | – | List of actively running operations successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
