Get Managed Result of Operation
Retrieves the Managed File ID of the final result of a completed Output Creation operation of a specific operation ID.
Request takes no content, and on success returns the Managed File ID of the output (file or directory) in the File Store.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/print/getManagedResult/{operationId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
operationId |
Operation ID of All-In-One operation |
Response
Success
200 OK |
Managed File ID of the output (file or directory) in the File Store |
text/plain |
If the
Result of completed operation successfully retrieved |
The "X-Result-Type" header could have one of the following values:
"Data-Set-ID" - the entity contains a dataSetID (only data mapping operation requested)
"Content-Set-ID” - the entity contains a contentSetID (last operation: content creation)
"Job-Set-ID" - the entity contains a jobSetID (last operation: content creation)
"Output-Streamed" - the entity contains a streamed output file (last operation: content creation)
"Output-Local-Filepath" - the entity contains absolute path of output file (last operation: content creation)
"Output-Managed-Info" - the entity contains ID of persisted output file(s) (last operation: content creation)
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Operation not found in Server |
