Get Progress of Operation
Retrieves the progress of a running All-In-One operation of a specific operation ID.
Request takes no content, and on success returns a response containing the current value of operation progress (values ranging from 0 – 100, followed by the value of 'done' on completion).
Request
Method Type:
GET
URI:
/rest/serverengine/workflow/print/getProgress/{operationId}
Content: –
Content Type:
Add. Headers:
Parameters
Path
operationId
Operation ID of All-In-One operation
Response
Success
200
OK
Progress value of All-In-One operation text/plain – Progress of operation successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
