Process All-In-One (JSON)
Submits a request to initiate a new All-In-One operation.
Request takes a JSON All-In-One Configuration as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/print/submit
Content: JSON All-In-One Configuration containing workflow processes/parameters
Content Type:
application/json
Add. Headers:
Response
Success
202
Accepted
  • operationId – Operation ID of new All-In-One operation
Error
400
Bad Request
application/json
Required Input resource/file not found in File Store
401 Unauthorized
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
General error with running the All-In-One Process or a specific error relating to an individual workflow process (see error description)
