Authenticate/Login to Server
Submits an authentication request (using credentials) to the Connect server and if successful provides access to the various other REST API services available.
Request takes no content, but requires an additional Authorization header which contains a base64 encoded set of credentials (username and password). On success, the response will return an authorization token which can then be used as an additional auth_token header in any future requests made to the REST API services.
If server security settings are enabled and a request is made to any resource of any service in the REST API, if that request contains neither an auth_token header or an Authorization header, then the response will come back as Unauthorized and will contain an additional WWW-Authenticate response header.
Request
Method Type:
POST
URI:
/rest/serverengine/authentication/login
Content: –
Content Type:
Add. Headers:
Authorization – Basic Authentication (Username and Password) credentials (Base64 encoded)
Response
Success
200
OK
Authorization Token text/plain Token-Expires-In - The number of seconds the token is valid Server authentication successful, new authorization token generated.
Error
401 Unauthorized
application/json
Response when either:
  • no basic authentication credentials have been specified in the request headers
  • the basic authentication credentials specified in the request headers are invalid.
