Get Result of Operation
Retrieves the final result of a completed Content Creation (Email) operation of a specific operation ID.
Request takes no content, and on success returns a response containing a JSON Email Output List of all the email output messages created in the File Store.
Alternatively, if the operation was to create email output directly to a SMTP mail server, then a response containing a report on the number of emails that were successfully sent will be returned instead.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/email/getResult/{operationId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
operationId |
Operation ID of Content Creation (Email) operation |
Response
Success
200 |
JSON Email Output List of the email message output in File Store |
text/plain |
Result of completed operation successfully retrieved Response when the email parameters specified in the original request that created the operation does not contain a host value specifying the network address or name of a SMTP mail server |
200 OK |
Result of Content Creation (Email) Operation (with successful email count) (e.g. "3 of 3 emails sent") |
text/plain | – |
Result of completed operation successfully retrieved Response when the email parameters specified in the original request that created the operation contained a host value specifying the network address or name of a SMTP mail server |
Error
400 |
application/json |
Context not found / Section not found |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Operation not found in Server |
