Process Content Creation (By Data) (JSON)
Submits a request to initiate a new Content Creation (Email) operation.
Request takes a JSON Record Data List (with Email Parameters) of the data values for one or more Data Records as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/email/{templateId} |
Content: | JSON Record Data List (with Email Parameters) specifying a list of data values for the Data Record(s) and parameters to be used for content creation |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
templateId |
Query
section |
Default section in template |
The Section of the Email context to export |
Response
Success
202 Accepted |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
